48bit to 24bit Conversion Warning
coolspot
Post by coolspot »
XnView by default displays a warning that informs the user that 48-bit to 24-bit conversion is occuring if the colour depth is >24 bits.
I clicked the "Do Not Show Again" option, but now I want the dialog to show up again.
How do I re-enable the warning?
Thanks!
marsh
Re: 48bit to 24bit Conversion Warning
Post by marsh »
To reset warning dialogs: close program, remove line named "ShowAgain" in xnview.ini (settings file); underneath [Start] section. The 'about' dialog will show its location.
coolspot
Post by coolspot »
marsh wrote:To reset warning dialogs: close program, remove line named "ShowAgain" in xnview.ini (settings file); underneath [Start] section. The 'about' dialog will show its location.
Great thanks; I was looking for something like "8bit" "warning" etc in the .ini file ;)
Just curious, will XnView support 48-bit image manipulation in future release? Even basic features like rotate would be great.
coolspot wrote:Just curious, will XnView support 48-bit image manipulation in future release? Even basic features like rotate would be great.
No, but yes for a future version of XnViewMP
