Hi!
First of all,thx for your wonderfull programm )
ive got few questions:
1) Is it possible using command-line print whole folder or wildchar(*)? For exmp: xnview /print c:\temp\*. jpg?
2) Can i select custom printer instead of one which already selected through GUI when i using command-line print with "-ini" key?
May be i must somehow correct xnview.ini file or smthn else...
Command line /print *.jpg, ini printer select
Mistique
- Forum Librarian
Re: Command line /print *.jpg, ini printer select
I don't have a definitive answer to your question, but perhaps you'll find some of this information useful:
Mistique
Thnx, but all that stuff doesnt suits me...(
For example, I use cmd like this^:
""C:\Program Files\XnView\xnview.exe" -ini "\\srvbuh\Scan\_Xnview\xnview.ini" -print "\\server\Scan\_Xnview\testImage.jpg ""
Only after couple experiments I understand that "-ini" MUST be place as first param and there MUST exist only [Print] ini-file block, in other case I prints with XnView GUI params...
I need option to select custom, instead of default, printer.
And a ability print files using "*.jpg"
