Cannot add "Browse with XnViewMP" to context menu
afatac
Post by afatac »
Even after I have enabled it and click OK, the setting is always not saved, i.e. the box is always uncheck.
Re: Cannot add "Browse with XnViewMP" to context menu
Do you start XnViewMP with admin rights?
afatac
Post by afatac »
Oh yes, have to start xnview.exe using "Run As Administrator"... even my Windows user account type is administrator. Using Windows 7.
Thanks.
budz45
Post by budz45 »
afatac wrote:Even after I have enabled it and click OK, the setting is always not saved, i.e. the box is always uncheck.
All is fine for me, no issue :)
