favourites reorder
harumscarum
favourites reorder
Post by harumscarum »
it is very tricky to reorder favorites since no such an options I need to delete it all and create again in the correct sequence
budz45
Re: favourites reorder
Post by budz45 »
Yes,
In 'Favourites' there needs to be support for:
• Support for a "Remove all" item in the context menu (easy :) )
• Support for Drag & drop re-ordering
• Support for Drag & drop of folders from Browser
