Bart's PE Builder
Aokromes
Bart's PE Builder
Hi i have found a program that allows Windows to be run from a cdrom unit and i made a plugin for XnView. If you like to try it go to: PE Builder Forum - Plugin.
Aokromes
PE Builder is an app that allows you to run windows from a cdrom unit, you can add the programs that you like to use and with it you can go to travel with your favourites apps
The main idea of the software is to recover data from crashed Windows, but there are a lot of plugins that don't have nothing to do with it.
For example a plugin for Nero Burning Rom, SmartFTP (i have maked this one too), Mirc, Video Lan Client, PQ Magic and another freeware viewer, the reason of making the plugin for XnView.
It has plugins for most of the most used NIC adapters.
Pebuilder
Pebuilder
