File format JPS and MPO
pete3000
Post by pete3000 »
I have a 3D LG camera and i would like for you to add the JPS format and MPO file associations. they are simply jpgs. the difference is they are 2 images side by side. XNVIEW opens them fine (one at a time), but doesn't allow me to browse to the next JPS one in the folder.
Re: File format JPS and MPO
  1. Make sure Display all image file types (Tools » Options... » General » Operations) is activated.
  2. You might also have to switch off the Recognize only by extension setting (Tools » Options... » Browser » File List » Misc.).
You can also have XnView treat MPOs and JPSs as “companion files”:
livia
Post by livia »
Thanks for the help, I was wondering how to set this up on my LG 3d cam also.
