MP 0.48 WinXP: Custom toolbars do not persist
JohnFredC
Post by JohnFredC »
  • 1. Create a custom toolbar in Options
    2. Apply the custom toolbar
    3. Observe custom toolbar is present
    4. Close MP
    5. Reopen MP
    6. Observe default toolbar, NOT custom
Very inconvenient!
BTW, this behavior was present in 0.38 as well.
John
Re: MP 0.48 WinXP: Custom toolbars do not persist
I can't reproduce, do you have a default.bar?
JohnFredC
Post by JohnFredC »
Hi Pierre, glad you are back!
Yes there is a default.bar file. All my toolbar files are stored in the folder with the executable, though I am thinking of moving them to a sub-folder.
The proper behavior (between sessions) should be to persist whatever toolbar(s) the user has selected in the previous session.
A checkbox "[x] Use this toolbar next time" might be a useful option for some users (but not for me: I will never use the default toolbars).
John
So you have loaded a mytoolbar.bar, and at next startup xnview will not use it, right?
JohnFredC
Post by JohnFredC »
Exactly... MP reverts to the default bar at next startup.
John
JohnFredC wrote:Exactly... MP reverts to the default bar at next startup.
:( I can't reproduce, i load a saved toolbar, quit, and start, i have the good one
Could you send me the default.bar & custom.bar?
