RC6: Compare dialog: Auto Image rotation
In the compare dialog (Tools > Compare...) the image files are not auto oriented. Think if setting 'Use ExIF auto rotation' is active, this setting should also apply for the compare dialog.
Re: RC6: Compare dialog: Auto Image rotation
Yes normalhelmut wrote:In the compare dialog (Tools > Compare...) the image files are not auto oriented. Think if setting 'Use ExIF auto rotation' is active, this setting should also apply for the compare dialog.
Not sure what the above reply means, but this is verified fixed in RC7. Thanks, Pierre.xnview wrote:Yes normalhelmut wrote:In the compare dialog (Tools > Compare...) the image files are not auto oriented. Think if setting 'Use ExIF auto rotation' is active, this setting should also apply for the compare dialog.
