0.39 and 0.48: browser folder changed afer save a file
rmtk
Post by rmtk »
1. Open XnviewMP and open a picture in browser folder A.
2. Save it to folder B (in viewer tab).
3. Close the viewer tab.
Now the folder shown in browser tab is B instead of A.
Is this a bug? For me I want to see the brower folder continue to be A.
budz45
Re: 0.39 and 0.48: browser folder changed afer save a file
Post by budz45 »
Judging from your reproduction steps, yes, it seems like a small bug
Are you sure you have enabled the setting "Synchronize browser when view is closed" ??
And if you disabled "Synchronize browser when view is closed"?
rmtk
Post by rmtk »
Yes, I enabled "Synchronize browser when view is closed".
Disable this setting solve it.
budz45
Post by budz45 »
So this is not a bug then, thank goodness :D
