xnview 0.48: chrash after several thumbnail resizings
Jou
Post by Jou »
A folder with 34 .jpg files, 1920x1200 (=screen resolution), , move the slider between 11 and 13 times (wait until the thumbs are created) and xnview 0.48 will crash. The memory usage goes up and down depending on the thumbnail size.
Deleting the 170 MB xnview.db + the journal seems to fix it temporarily.
However the issue can be forced if you do NOT wait until all thumbs are created and wildly move the slider around, the crash happens sooner then.
Reproducible: It takes a while until it appears again, xnview.db needs to be rather big with a huge number of thumbnails (not just big thumbs to blow it up).
Eventviewer output (four version of hex numbers put in one line if they change):
Name der fehlerhaften Anwendung: xnview.exe, Version: 0.40.0.0, Zeitstempel: 0x4f8fd4d3
Name des fehlerhaften Moduls: QtGui4.dll, Version: 4.8.0.0, Zeitstempel: 0x4f21ba36
Ausnahmecode: 0xc0000005
Fehleroffset: 0x0017a880
ID des fehlerhaften Prozesses: 0x1640 / 0xd5c / 0x814 / 0xfc0
Startzeit der fehlerhaften Anwendung: 0x01cd2e259f5e85eb / 0x01cd2e256c0f28a6 / 0x01cd2e2532e4fd8f / 0x01cd2e248c520cf1
Pfad der fehlerhaften Anwendung: C:\prog\XnViewMP\xnview.exe
Pfad des fehlerhaften Moduls: C:\prog\XnViewMP\QtGui4.dll
Berichtskennung: fd752da5-9a18-11e1-96ff-002522f4b13a
Just for completeness: my config attached.
I'll send the next port on this topic when it starts to manifest again, cant force it to reappear right now.
Gaming in 4k / 6k / 8k / 15k / 16k? Yes! https://joumxyzptlk.de
Re: xnview 0.48: chrash after several thumbnail resizings
When you move the slider, do you release the mouse button??
Jou
Post by Jou »
xnview wrote:When you move the slider, do you release the mouse button??
Yes.
It happened today again (after 8 slider movements):
.db about 230 MB.
The directory browsed contains 194 pictures.
Maybe a race condition once the .db has a specific size or contains a larger number of thumbs? The DB is on a SSD, the directory browsed is on a fast SATA HDD.
ID des fehlerhaften Prozesses: 0x62c
Startzeit der fehlerhaften Anwendung: 0x01cd2ec1647a484f
Berichtskennung: b9ff838b-9ab4-11e1-96ff-002522f4b13a
If you have only 8-10 pictures, same crash?
Jou
Post by Jou »
Yes, crash with 9 picture too. It happens with two pictures too.
But the event is different with two pictures and it does not blame QtGui4.dll.
When using the left and right cursor keys instead of the mouse it crashes too.
xnview.db deleted, folder with 2 picture in 1920x1200 (1x1x1 sampled, converted from .bmp with xnview-classic), crash can be forced too.
Event for 9 pictues:
ID des fehlerhaften Prozesses: 0x1918
Startzeit der fehlerhaften Anwendung: 0x01cd300ee4414fb9
Berichtskennung: 43061450-9c02-11e1-9d91-002522f4b13a
Event for two pictures:
Name des fehlerhaften Moduls: MSVCR90.dll, Version: 9.0.30729.6161, Zeitstempel: 0x4dace5b9
Fehleroffset: 0x00024673
ID des fehlerhaften Prozesses: 0x17a8
Startzeit der fehlerhaften Anwendung: 0x01cd300f1ba225cf
Pfad des fehlerhaften Moduls: C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCR90.dll
Berichtskennung: 7ff1742a-9c02-11e1-9d91-002522f4b13a
Event for two pictured with fresh xnview.db:
Fehleroffset: 0x0003ae7a
ID des fehlerhaften Prozesses: 0x194c
Startzeit der fehlerhaften Anwendung: 0x01cd300f83fa2f8f
Berichtskennung: e18efb32-9c02-11e1-9d91-002522f4b13a
Could you send the 2 picture to try to reproduce?
Jou
Post by Jou »
Here they are (too big for forum):
http://oron.com/gb0bgxdldtwc
Say when you got them so I can use the kill-link.
Ok, i have it
I can't reproduce :( I've tried with right arrow on slider, but no problem...
