The "Iconify tabs" feature is useful Tab GUI enhancement feature for XnViewMP
...However currently I think it could do with a little snazzy eye-candy added to it! same as above animated GIF----> http://i.imgur.com/Fwgmq.gif
Therefore, I would like to see some tab animation for the "Iconify tabs" feature within XnView MP 0.48 +higher
...As seen in Opera 11+ "pin tabs" feature, the tab smoothly resizes inwards and outwards when pinning a tab. http://i.imgur.com/F5m8V.gif
I believe Opera browser is using the same or similar Qt interface framework as XnView MP to support this.
Chrome browser also is another fine example of such animation.
Note: Tab animation already exists (can be seen) with tab re-arranging in XnViewMP (due to Qt)
Animation requested for:
• Opening any tabs
• Closing any tabs
• Iconify tabs
• Duplicating tabs
• Drag & drop file to tab bar opening/closing
• 'Captures' tabs opening/closing
• "Close other tabs"
• tab Opening = Fast jump Bounce animation for opening
• tab Closing = Shrink then fade out (like Chrome browser)
This feature will be purely optional and would be disabled by default.
