EDIT: I made a confusion between XnConvert 1.10 (this report) and MP 0.48 (original caption of the post). This thread can be erased.
Some small issues:
- The display of the status should have an auto-scroll to display always the latest lines in status.
- At minimum the status should display the end of the report when the batch is done.
- Progress bar displays 100% although there are some files remaining.
Peter
"Status-Display" in XnConvert 1.10
Peter2
Re: "Status-Display" i current 0.48 beta
When you move the scrollbar?Peter2 wrote: - The display of the status should have an auto-scroll to display always the latest lines in status.
Perhaps you have a lot of files? (a round problem)- Progress bar displays 100% although there are some files remaining.
Peter2
No, when the batch is working. The display should be a kind of "auto-scrolling": Always show the end of the log. And if "always" is not possible, then "show end of log at the end of batch job."xnview wrote:When you move the scrollbar?Peter2 wrote: - The display of the status should have an auto-scroll to display always the latest lines in status.
EDIT:
My report above is based on XnConvert 1.10. Current MP0.48 does it as suggested.
I don't think so, but I will watch it and report - if I can reproduce.xnview wrote: Perhaps you have a lot of files? (a round problem)
Peter
Peter2
Re: "Status-Display" in XnConvert 1.10
Peter
Peter
