Convert Multiple Jpeg to Tiff (CCITT Group 4 BW)
dignidad001
Post by dignidad001 »
I have several JPEG files that I need to convert simultaneously to TIFF with the following properties:
Format: TIFF
#bits 1
Colour Model: B&W
Compression CCITT Group 4
I can only do it one at a time by going to Tools/Export. My goal is to have these images converted all at the same time :( since
I'll be doing several sets of this :(
Re: Convert Multiple Jpeg to Tiff (CCITT Group 4 BW)
dignidad001
Hi , I tried the batch processing option:
Format: Tif-Tiff Revision 6
Select options
Binary Compression: CCITT G4
Colour Compression - no option for BW
The file i'm getting is also too big.
  1. Tools » Batch Processing... » Transformations
  2. Convert » Convert to Binary » Add >
  3. Convert to Binary » Parameters » No dither
Related topics:
dignidad001
Related topics:
Thanks, almost there....
This time the output I get is
Format: Tiff
Colour Model: B&W
Compression: None
And the file is still to big. The size i'm looking at is just around 177KB
dignidad001
still can't figure it out :(
Use CCITT as compression
dignidad001
xnview wrote:Use CCITT as compression
Hi Pierre,
I can't see the option to select CCITT as compression when doing Batch Processing. This is while doing the steps provided by XnTriq above.
All I see is under the General Tab, I can select only the Format (TIF - TIFF Revision 6).
Peter2
Post by Peter2 »
The options are here:
Options (F12) - General - Read/Write - Write - Select TIFF from list - select colour and binary compression.
Peter
dignidad001
Peter2 wrote:The options are here:
Peter
Hi Peter,
What Colour Compression will I select?
Colour Compression: None, Packbits, LZW, LZW+Predict, ZIP, JPEG
Peter2
Post by Peter2 »
You wrote:
dignidad001 wrote:...
Format: TIFF
#bits 1
Colour Model: B&W
So it is clear:
In "write options" you set "CCITT", in batch conversion you set B&W. Further details and backgrounds on the formats should be googled / yahooed / Binged ...
Peter
dignidad001
Format: TIFF
#bits 1
Colour Model: B&W
So it is clear:
Peter
Finally got it!!! Thanks a lot :mrgreen:
Peter2
Post by Peter2 »
Maybe I'm wrong, but your posting has nothing to do with the title of this thread - and it sounds like a free advertisement for a commercial product :x :x
Peter
