Suggestions - Info tabs
chairpotato
Post by chairpotato »
There is a lot of scrolling to do in the info tabs because every time I select a different file the position resets to the top of the tab. Mostly I look at the same field as I'm moving from file to file so it would be helpful if the tabs would keep their place, even after switching from one tab to another. Maybe it could go back to the top if I double click the tab.
I wish I could create custom tabs so I can pick my most often sought after information accross the different tabs and collect/sort it in one or a few tabs.
Some actions would be useful on data in the tabs like find, sort by, highlight or select on the files that match. For example I have one file selected, I go to the IPTC tab in info pane and right click on keywords, a context sensitive menu appears with, for example the above mentioned actions. If I select find then the search dialog opens up with the condition:IPTC:keywords-is any of-"data" already -filled in and perhaps the current folder.
Re: Suggestions - Info tabs
yes custom tab will be great...
