tag
bdconnell
tag
Post by bdconnell »
I am trying to understand why I would use tag of images versus selection of images. Selection seems to be what operations on multiple photos work with (i.e. open, edit, etc). It seems I can tag a number of images, and then view only the tagged images, but I cannot find a way to go back and view all images (tagged and untagged) in case I want to add an untagged image to the set. What are tags intended to be used for?
Oh BTW, I am a new user and this program is exactly what I was looking for. Very complete, very customizable. Great job!
Re: tag
you have Tag>Show tag
Re: tag
  • Tools » Options... » Browser » Thumbnails » Icon info
    • Tagged files must be cleared
      • After an operation
      • After folder change
      • On exit
      • Never
debragon
Re: tag
Post by debragon »
Just select "View all" and the list images should appear.
