(I'm not a specialist in this case so maybe my wording will sound a little bit strange).
Many applications "lock" the file which is opened: When I try to open the same opened file I get an alert, and there are some commands which show the user if the file is used/opened/locked by another user.
How does XnView handles this situation? Does it "lock" the files? if yes - how to find it out in Windows?
Regards
Peter
How does XnView "locks" open files?
Peter2
- Forum Librarian
Re: How does XnView "locks" open files?
In my experience, XnView's browser locks directories.
I never ran into problems with files that were in use.
- NirSoft: OpenedFilesView
- Cédrick Collomb (ccollomb): Unlocker
- Dr. Hoiby: WhoLockMe
- Microsoft
- Windows Sysinternals: Process Explorer / Handle
- Windows 2000 Resource Kit Tools for administrative tasks
oh.exe (Open Handles) / inuse.exe (File-In-Use Replace Utility) - Windows Server 2003 Resource Kit Tools
- Ramesh Srinivasan: Know which process has locked a file
- WinHelpOnline Blog: View Open Handles to a File or Folder From the Context Menu
