Is it possible to use nconvert in visual basic with the shell-command
i'd tried to use the following statement, but it did not work
x=shell(d:\nconvert.exe -o file_out.jpg file_in.jpg)
any suggestions?
Nconvert and Visual Basic
I've just checked and the sample below works for me. Though the correct paths are an issue: If you do not specificy paths, I think the current dir, that is the directory where the running VB application resides in, will be used. To be on the save side make sure you specify valid paths for nconvert, input and output file.
Not sure in your case, but I recommend you to have a look at GFL SDK.
Dim taskID As Double
taskID = Shell("C:\Program Files\XnView\nconvert.exe -o D:\file_out.jpg D:\file_in.jpg")
