Batch Move
MatthiasG
Batch Move
Post by MatthiasG »
it would be of help if the batch rename feature would offer a possiblity to move pictures to subfolder. I tried to add a \ to the template, bute that gives only - in the filename.
It would be helpful to organize picture (from scattered sources) into structured folders.
Example:
Sources:
Define a Template
C:\out\<PictureDate>\<Name>.<Extension>
Result after move
that would really help to organize large sets of images.
Also applies to XnViewMP.
Regards,
Matthias
Re: Batch Move
This suggestion might be of interest to you: Batch Processing "Move File" function
MatthiasG
Re: Batch Move
Post by MatthiasG »
Your suggestion seems to apply to the transform dialog. To save the results in a folder which depends on the transform options.
I would like to ahve an option to move thwe files based on their metadata.
May this can be implemented in the same dialog, but I leave this question to the developers.
Regards,
Matthias
