about the "move/drag" dialog...
Zheitk
Post by Zheitk »
Everytime I drag some picture to a subfolder, the "moving" dialog just stays idle for 2-3 seconds with "done" in the title. Worse if the folder have 2k+ pics I have to move, it takes about 5-8 seconds to the program to respond.
Is there a way to make this faster or disable the dialog (pretty cool and usefull, by the way U_U)
Re: about the "move/drag" dialog...
with 0.39?
Zheitk
Post by Zheitk »
xnview wrote:with 0.39?
This is under a standard 5400rpm laptop drive, with XP and xnviewmp v0.48
If the folder has a few pics, it's just the 2sec idle "done" dialog.
If the folder has 2000+/-, xnview.exe takes full cpu usage (50% in a dual core) and it gets frozen for 12.331 seconds
Meanwhile, windows explorer (after 2m of generating the thumbnail cache ¬_¬) moves the files almost instantly, so I don't think this is because my slow hdd.
Saludos 8)
