Behaviour of opening tabs
Zungao
Post by Zungao »
When reviewing photos i have the browser showing the thumbnails. I double-click on a thumbnail to inspect the full size photo, then double-click again to return to the browser. This opens a new tab for each image. Is it possible to prevent this and open only one tab per folder?
Another question (new user here :mrgreen:): what is the "Single view for multi opened files" option? I assumed that when turned "off", opening a selection of files would open one tab for each, and when "on" only one tab would open to show the selected files. However I cannot see any diference and it allways behaves in the latter fashion.
Regards,
Z
budz45
Re: Behaviour of opening tabs
Post by budz45 »
Zungao wrote:This opens a new tab for each image. Is it possible to prevent this and open only one tab per folder?
Have you tried changing the 'Maximum view tabs' to "1" ? -----------> the setting is in Settings > Interface > Tabs
Zungao wrote:Another question (new user here :mrgreen:): what is the "Single view for multi opened files" option? I assumed that when turned "off", opening a selection of files would open one tab for each, and when "on" only one tab would open to show the selected files.
Yes, correct :D
Zungao wrote:However I cannot see any diference and it allways behaves in the latter fashion.
What file-opening method are you using to open your multi image files?? From Browser and from Windows file Drag & drop the setting when enabled does work :mrgreen:
Zungao
Post by Zungao »
budz45 wrote:Have you tried changing the 'Maximum view tabs' to "1" ? -----------> the setting is in Settings > Interface > Tabs
Thanks, hadn't noticed that! To be perfect though, I'd like to have the option to set either:
"Maximum view tabs per folder"=1
"Maximum total view tabs"=no limit
or perhaps even better:
"Open each photo in new view tab"=no (and then have a way to force a thumbnail to open in a new view tab)
"Maximum view tabs"=no limit
budz45 wrote:What file-opening method are you using to open your multi image files?? From Browser and from Windows file Drag & drop the setting when enabled does work :mrgreen:
I have a "Browser" tab with just a folder tree on the left and a tumbnails (large size) pannel on the right. To view a photo in full size I double click on it's thumbnail. To go back to the browser I double-click again.
When selecting several files by shift-clicking on them and then pressing enter it does not appear to work :?:
budz45
Post by budz45 »
Zungao wrote: "Maximum view tabs"=no limit
Do you really think that XnView MP should be able to open an unlimited amount of tabs? It is not a Internet Web Browser...
If you think unlimited tabs is necessary for your needs then perhaps the current limit could be increased from '99' to '1000' OR perhaps an abilit to enter a character into the spinbox value like a hyphen "-" which would give the unlimited.
Zungao wrote:"Maximum view tabs per folder"=1
You would like an ability for a single view tab per folder...So that View tabs each opened for a folder directory? So that if opening another picture from Browser that is from the same folder it would switch to that already opened tab?
Zungao wrote:I have a "Browser" tab with just a folder tree on the left and a tumbnails (large size) pannel on the right. To view a photo in full size I double click on it's thumbnail. To go back to the browser I double-click again.
Oh ok, the double-click switching method :) (between Browser and View)
Zungao wrote:When selecting several files by shift-clicking on them and then pressing enter it does not appear to work :?:
What is the result you are getting when you do this? The files you are multi selecting in the Browser are Image files, correct?
Are you sure you have the feature enabled in the 'Settings'? Please also test this feature yourself with Drag & drop of multi image files from Windows Explorer, just as a test.
Zungao
Post by Zungao »
budz45 wrote:Do you really think that XnView MP should be able to open an unlimited amount of tabs? It is not a Internet Web Browser...
I put no limit as a "figure of speech". I've set "tab limit"=1, but if the "tabs per folder" option were available I would use four or five tabs. However different people work in different ways and I wouldn't define an arbitrary number (such as 20 or 30). If however the current limit is 99 this should be (way) more than enough.
budz45 wrote:So that if opening another picture from Browser that is from the same folder it would switch to that already opened tab?
Precisely :D
budz45 wrote:What is the result you are getting when you do this? The files you are multi selecting in the Browser are Image files, correct?
They are all jpeg images. And only the first image of those selected opens.
budz45 wrote:Are you sure you have the feature enabled in the 'Settings'? Please also test this feature yourself with Drag & drop of multi image files from Windows Explorer, just as a test.
It is selected. And I've even closed and reopened XnViewMP between changes in case the setting would need a restart.
Drag&dropping images from windows explorer to an already open view tab does work as expected. And so does drag&dropping several thumbnails to empty space on the the tab bar. (I hadn't tried this before).
However, if I select a few thumbnails and press enter (or use the open option on the context menu) it always acts as if "Single view" is enabled, regardless of the setting.
budz45
Post by budz45 »
Zungao wrote: I put no limit as a "figure of speech". I've set "tab limit"=1, but if the "tabs per folder" option were available I would use four or five tabs. However different people work in different ways and I wouldn't define an arbitrary number (such as 20 or 30). If however the current limit is 99 this should be (way) more than enough.
Thank you for the explanation. Yes the arbituary number of '99' is more than enough for the average user however I see the visual concern a user might have with he imposing of a limit. :) As I said before a totally unlimited option for tabs could still be made available (e.g. if spinbox goes below '1' it would show a hyphen "-" to signify unlimited number).
Precisely :D
Ok, the 'tabs per folder' suggestion sounds like an interesting idea for a future feature and I can imagine the workflow. Perhaps as an experimental feature it could be added as an Ini Tweak (see topic).
Zungao wrote: However, if I select a few thumbnails and press enter (or use the open option on the context menu) it always acts as if "Single view" is enabled, regardless of the setting.
Right, so a bug :bug: with the "Single view.." setting not responding for Browser....Only just recently I sent Pierre an email about this.
budz45
Post by budz45 »
Precisely :D
Hi again,
Yes I too would now like to have this feature and would find it very useful in some circumstances. I think that the feature should be named "Single view per folder directory" :D
