RC7: Status line bug 1: Missing first image data
Lesmo16
Post by Lesmo16 »
The image data information in the status line isn't ever shown for the first image.
It's only when pointing with mouse on it - keyboard navigation works fine.
This occurs in all layouts.
XnView 1.80 <x>
Everyone who believes in telekinesis, raise my hand!
ckit
Post by ckit »
I can't re-produce this bug.
Post by Guest »
FYI: This was in all 1.80 RCs - don't know about 1.74 ...
Re: RC7: Status line bug 1: Missing first image data
Lesmo16 wrote:The image data information in the status line isn't ever shown for the first image.
Yes, sometimes when you change folder
Lesmo16
Post by Lesmo16 »
That may be true for the *first* click on the first thumbnail, although I can't confirm it.
But when you are in a folder, and focus is on a thumbnail other than first - and then you click on the first thumbnail - there's *never* that data.
So my experience is: Only the very first click on the first thumbnail gives the data.
If I had seen this thread first, I would have been posting there - sorry!
Lesmo16
Post by Lesmo16 »
FYI: This bug doesn't exist in ver 1.74 - just checked it. :(
Lesmo16
Post by Lesmo16 »
The field for selected files [....MB] isn't automatically adapted, the right bracket is truncated.
That occurs if only one thumbnail is marked. If more are marked, the right bracket is shown.
Still remains in 1.80 re-test ... :?
Lesmo16 wrote:The field for selected files [....MB] isn't automatically adapted, the right bracket is truncated.
Ok, i fix it
Lar5
Post by Lar5 »
Lesmo16 wrote:It's only when pointing with mouse on it - keyboard navigation works fine.
:?: How do you actually move focus to the thumbnails without the mouse?
Lesmo16
Post by Lesmo16 »
Lar5, you have to set focus to one thumbnail of your choice with mouse.
But from then on, you can navigate with keyboard.
When you go to first thumbnail with left arrow key, you'll get the correct data.
In the browser the 'Tab key' will change between the panels in the following order:
Folder tree > Address > File list > Folder tree
If you are in the file list and nothing is selected (bug?), you simply press one of the cursor keys, the first thumbnail will be selected then. Then you can navigate with the cursor keys and select images using Shift + Cursor keys.
Lar5
Post by Lar5 »
helmut wrote:If you are in the file list and nothing is selected (bug?), you simply press one of the cursor keys, the first thumbnail will be selected then. Then you can navigate with the cursor keys and select images using Shift + Cursor keys.
Perfect! Thanks a lot :D
Hacker
Post by Hacker »
Ok, i fix it
Partly fixed.
With Preview disabled only number of files / size is shown.
With Preview enabled all info is shown.
Disabling Preview again adds to number of files / size also file name and comment, but the comment isn't updated when I click another image.
1.80.1.
Roman
