Turn off double click to exit fullscreen
I am having trouble fast cycling through pictures in fullscreen as anything interpreted as a double click exists fullscreen, is there are any way to turn the double click=exit feature off, so I can just press ESC instead?
Re: Turn off double click to exit fullscreen
OK, I see in Options>General>Keyboard/Mouse you can turn off double click in switching mode which stops it exiting full screen, but then it seems only a double click will go to next picture, one single click does nothing, I would prefer single click to go to next picture, but that is not offered as an option.
I have started a bug report as it seems impossible to go through all images in a folder in full screen without problems
http://newsgroup.xnview.com/viewtopic.php?f=36&t=25886
OK, the issue is that right click goes forward, rather than left which you do not seem to be able to change (so I was continually going backwards & thinking it was freezing when it got to start of the folder). The other issue is that if you click too closer together it gets taken as a double click but as you set nothing to happen, nothing happens. It would be better if double click is disabled that all clicks are taken as single clicks.
