Follow on from my support topic here
http://newsgroup.xnview.com/viewtopic.php?f=35&t=25885
I think there is a general bug, if you go into fullscreen you cannot cycle through images in a folder properly, it will either freeze after a few images if you have double click disabled or send you back to the viewer if you have double click enabled.
Using Windows 7 32 bit.
Problems with cycling images in full screen
gouache
Re: Problems with cycling images in full screen
OK, so if I select Options>View>Loop on the file list , it allows to cycle through all images but for some reason left click goes backwards, right goes forwards which seems counter intuitive, is there a way to reverse this?
