when converting to jpeg2000, icc color profile of the output image is always set to sRGB, regardless of the original input profile.
I have checked to preserve color profile in both output tab and jpeg2000 format settings. I have even tried to select to preserve profile only in output tab or format setting tab, to no avail. Profile is always set to sRGB – not converted, so colors appears different when the image is opened. I use Photoshop and Preview app to check the profile.
My system is Lion 10.6.4, XnConvert 1.20 x64. 32bit version always returns convert error on my system (don't know why). Version 1.10 has the same problem with icc.
Windows version 1.20 also contains this bug.
Is there any way how to fix this? XnConvert would be the best app ever if this error is fixed! Thank you!
Regards Tom
XnConvert 1.20 MAC WIN not preserving icc profile jpeg2000
aTomJak
Re: XnConvert 1.20 MAC WIN not preserving icc profile jpeg20
Yes, currently icc can't be saved in jpeg2000
aTomJak
OK, that's unfortunate. Will it be possible in future? I thought I have finally found the solution I need to convert my whole photo folder to jpeg2000
Is there any alternative solution currently?
