XnView 0.50
asa
XnView 0.50
The 0.50 version refuse to work with OS X 10.6.8
Re: XnView 0.50
Which version do you have downloaded?
FS0903
Re: XnView 0.50
Confirmed. XnViewMP 0.50 64Bit is not starting at MacOSX 10.6.8. No error available from GUI. Error from terminal is:
dyld: Symbol not found: _kCFWebServicesProviderDefaultDisplayNameKey
Referenced from: /Applications/XnViewMP.app/Contents/MacOS/./../Frameworks/QtWebKit.framework/Versions/4/QtWebKit
Expected in: /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
Trace/BPT trap
Trace/BPT trap
asa
Re: XnView 0.50
Both 32 & 64 bit. The effects are the same.xnview wrote:Which version do you have downloaded?
Re: XnView 0.50
And XnConvert?asa wrote:Both 32 & 64 bit. The effects are the same.xnview wrote:Which version do you have downloaded?
Do you have tried with Mac AppStore?
StreamThreader
Re: XnView 0.50
Slackware Linux 13.37
I have a error message.
/usr/lib64/xnview/xnview: error while loading shared libraries: libpulse-mainloop-glib.so.0: cannot open shared object file: No such file or directory
In Slackware Linux pulseaudio not installed by default.
Why picture view program use Audio library?
Please include this lib as qt 4.8.2 and exiftool in package.
Thanks!
Thanks!
asa
Re: XnView 0.50
XnConvert version 6.10 is OKxnview wrote:And XnConvert?
