- "Auto image size" upon "/" key doesn't work anymore. Works fine on version 0.39.
- Crashes when changing images too fast. E.g. if I scroll with wheel (mouse wheel set to next/previous) or PgUp/Down quick enough.
## MyPreviewThread :: ERROR : 0 (0xac49db0) m_stopCondition.wakeOne() m_loadCondition.wait() ## threadFinished to cache 2 /media/images/img1.png (/media/images/img1.png) (0xac49db0) MyPreviewThread :: stop() A /media/images/img4.png (3166 900) A /media/images/img3.png (2930 754) ##ADD to cache 2 /media/images/img1.png P /media/images/img3.png (2930 754) P /media/images/img1.png (2100 664) ##REMOVE from cache 1 /media/images/img3.png (2930 754) /media/images/img1.png (2100 664) MyPreviewThread :: stop() A /media/images/img1.png (2100 664) ##ADD to cache 2 /media/images/img2.png P /media/images/img1.png (2100 664) P /media/images/img2.png (2100 664) setCurrentFilename </media/images/img3.png> BITAMP VIEW 1 2930 754 2930 754 100.000000 100.000000 ### resetViewport (ac03798) ==> 1311 829 (2930 754) 1619 0 SIZE : 0 78 (-1) SIZE : 0 61 (-1) SIZE : 0 78 (-1) SIZE : 0 61 (-1) SIZE : 0 78 (-1) SIZE : 0 61 (-1) SIZE : 0 78 (-1) SIZE : 0 61 (-1) ##START cache 2 /media/images/img4.png /media/images/img1.png (2100 664) /media/images/img2.png (2100 664) MyPreviewThread :: stop() MyPreviewThread :: set ###### LOAD BITMAP </media/images/img4.png> PNG READ INFO ######################################## ############### UPDATE MENU ############ ######################################## MyPreviewThread :: stop() m_stopCondition.wait() ### crack *** glibc detected *** /opt/XnViewMP/XnView: double free or corruption (!prev): 0x0ac51110 *** ======= Backtrace: ========= /lib/i386-linux-gnu/libc.so.6(+0x6cbe1)[0xb4dc0be1] /lib/i386-linux-gnu/libc.so.6(+0x6e50b)[0xb4dc250b] /lib/i386-linux-gnu/libc.so.6(cfree+0x6d)[0xb4dc569d] /opt/XnViewMP/XnView[0x844264c] /opt/XnViewMP/XnView[0x8456745] /opt/XnViewMP/XnView[0x8458058] /opt/XnViewMP/XnView[0x8442167] /opt/XnViewMP/XnView[0x8442498] /opt/XnViewMP/XnView[0x844571e] /opt/XnViewMP/XnView[0x82154ee] /opt/XnViewMP/XnView[0x8080367] /opt/XnViewMP/XnView[0x829b144] /opt/XnViewMP/lib/libQtCore.so.4(+0x72b7d)[0xb5d41b7d] /lib/i386-linux-gnu/libpthread.so.0(+0x5e99)[0xb5cbbe99] /lib/i386-linux-gnu/libc.so.6(clone+0x5e)[0xb4e259ee]
XnViewMP 0.50
svlasov
XnViewMP 0.50
Re: XnViewMP 0.50
If you go slowly, no crash?[*] Crashes when changing images too fast. E.g. if I scroll with wheel (mouse wheel set to next/previous) or PgUp/Down quick enough.
Ubuntu 11.04 i386.
bencahill
Re: XnViewMP 0.50
I'm just trying out this software today, and am utterly impressed with its speed, even on my slower computer. Thanks for all the hard work!
I'm experiencing what sounds like the same issue, namely crashing with the "*** glibc detected *** /opt/xnviewmp/XnView: double free or corruption (out)" error when doing certain things fast. I've experienced the problem on three separate actions, although I can only remember one right now: changing the amount of info displayed with the thumbnails (i.e. Thumbnail, Thumbnail + Labels, etc.).
I can do some more testing, but would like to know what info would be most helpful to you first. I'm off to bed for today.
Re: XnViewMP 0.50
yes if you have a way to reproduce the crash...bencahill wrote: I can do some more testing, but would like to know what info would be most helpful to you first. I'm off to bed for today.
svlasov
Re: XnViewMP 0.50
To my understanding pressing the "/" key should switch between different "Fit image to window ..." modes but it does nothing. For example if the image size is bigger than the window size and the image is scaled to actual size (1:1) then by pressing "/" in version 0.39 the image would get scaled to fit the window, in 0.50 version xNview doesn't react to "/" key at all.xnview wrote:Which mode doesn't work??svlasov wrote:
Yes, it doesn't crash if I switch images slowly. Looks like a race condition when freeing memory twice after it's been freed already.If you go slowly, no crash?[*] Crashes when changing images too fast. E.g. if I scroll with wheel (mouse wheel set to next/previous) or PgUp/Down quick enough.
Ubuntu 11.04 i386.
Re: XnViewMP 0.50
I can't reproduce, with a clean xnview.ini? Only picture files in this folder? JPEG?svlasov wrote:Yes, it doesn't crash if I switch images slowly. Looks like a race condition when freeing memory twice after it's been freed already.If you go slowly, no crash?[*] Crashes when changing images too fast. E.g. if I scroll with wheel (mouse wheel set to next/previous) or PgUp/Down quick enough.
Ubuntu 11.04 i386.
svlasov
Re: XnViewMP 0.50
Only PNGs in the dir. I removed ~/.xnviewmp which was recreated again, still crashes.xnview wrote: I can't reproduce, with a clean xnview.ini? Only picture files in this folder? JPEG?
Re: XnViewMP 0.50
could you send me some samples of png that you have?svlasov wrote:Only PNGs in the dir. I removed ~/.xnviewmp which was recreated again, still crashes.xnview wrote: I can't reproduce, with a clean xnview.ini? Only picture files in this folder? JPEG?
svlasov
Re: XnViewMP 0.50
Attached.xnview wrote: could you send me some samples of png that you have?
Re: XnViewMP 0.50
Ok, please try to download the package again (a problem in first build)...
svlasov
Re: XnViewMP 0.50
Thanks! No more crashesxnview wrote:Ok, please try to download the package again (a problem in first build)...
svlasov
Re: XnViewMP 0.50
Found another bug. For some images in the View mode they look horizontally flipped, but fine in the Browser mode. As an example it happens also for png icons that come with XnView.
Re: XnViewMP 0.50
yes right... only on linux...svlasov wrote:Found another bug. For some images in the View mode they look horizontally flipped, but fine in the Browser mode. As an example it happens also for png icons that come with XnView.
