New image at the end of the directory
lian
Post by lian »
here I am again with my little obsession: new images put at the end of the directory, so not filtered as the others. Is there a simple way to refresh the view so the new images are back where they should be ? For the moment, I quit and run MP...
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: New image at the end of the directory
option>Filelist>New file at the end :)
lian
Post by lian »
Ahhhhhhhhh ! Thanks a lot ! Did not see in the new options - du coup, cette traduction incomplète est pratique pour voir ce qui a changé :-)
lian
Post by lian »
It's unfair: when selecting "New file at the end" and new files are created simultaneous (ex: using the Save Image Firefox Plugin), all the files are selected. Very convenient. But if "New file at the end" is not selected, no image is selected ! :?:
