[Fixed]Mouse cursor unavailable on more dialogues.
marsh
Post by marsh »
1. In fullscreen, <ctrl + shift +r> starts an information box about lossless jpg. The mouse cursor is unavailable to use with this warning box.
2. <ctrl +l> 'Standard slidehow'. Mouse cursor unavailable for this dialogue.
3. <shift + c> 'Canvas size' - same problem.
4. <shift +t > 'Add text to image' - same problem.
5. <ctrl + m > 'edit color map' - same problem.
6. <ctrl + n> 'sequence convert' - same problem.
7. <ctrl +u> 'batch convert' - same problem.
8. <ctrl + f> 'search' - same problem.
9. F1 'Information' - same problem.
10. <shift + y> 'auto crop' - same problem.
11. <ctrl + d> 'describe' - same problem.
12. <ctrl + p> 'print' - same problem.
13. <ctrl +h> 'open in hex mode' - same problem.
Problems in this thread are all fixed. v.1.82
Re: RC7: Mouse cursor unavailable on more dialogues.
marsh wrote:1. In fullscreen, <ctrl + shift +r> starts an information box about lossless jpg. The mouse cursor is unavailable to use with this warning box.
Ok, thanks
marsh
Post by marsh »
All fixed in RC7(latest) except:
9. <F1> 'Information' - not fixed. This box asks for the help file.
Dreamer
Post by Dreamer »
marsh wrote:All fixed in RC7(latest) except:
Not a bug... anyway, fixed.
Dreamer
marsh
Post by marsh »
Mouse cursor is unavailable for information box F1 brings up. So it is a tiny bug. Not important. Delete the help file to see this information box.
marsh
One more that was missed.
Post by marsh »
<ctrl + o> 'Open' - Mouse cursor unavailable in fullscreen with this shortcut.
Olive
Post by Olive »
^ Confirmed
Dreamer
Re: One more that was missed.
Post by Dreamer »
marsh wrote:<ctrl + o> 'Open' - Mouse cursor unavailable in fullscreen with this shortcut.
Right.
Moved back to "New/Open".
Dreamer
Dreamer
Post by Dreamer »
Not fixed in v1.80.1.
marsh
Post by marsh »
That is working for me in v1.80.1. Is it fixed for anyone else?
New problem:
<shift +e> adjust gamma,etc. mouse cursor unavailable.
Dreamer
Post by Dreamer »
Strange, maybe a silent update? My version is 1.80.1 Jul 4 2005 and yours?
Good here---
>> Dreamer
:) Hello !
• I've the same version than you, and it works alright here under Win 98 SE…
:mrgreen: K R
Post by Guest »
Dreamer wrote:Strange, maybe a silent update? My version is 1.80.1 Jul 4 2005 and yours?
Nope! I downloaded the zip package and checked the MD5 checksum and it matched the my old packages MD5 sum.
Post by Guest »
Nope! I downloaded the zip package and checked the MD5 checksum and it matched my old packages MD5 sum.
All works---
>> marsh
:) Hello !
- All shortcuts provide the mouse cursor (when there is one), and work here; maybe is it a specific issue of Win 2K ?
:mrgreen: K R
Locked
