Win7 X64
I receive the error message:
C\Program Files\XnViewMP\xnview.exe
This application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail.
X32 version is running on the same machine successfully.
0.50 Win-X64 could not start: Side-by-side configuration...
kostis57
Re: 0.50 Win-X64 could not start: Side-by-side configuration
Do you have installed the CRT from microsoft (in the x64 package)
kostis57
I downloaded and installed this:
http://www.microsoft.com/en-us/download ... x?id=14632
Is that what you mean? Problem persists.
Kostis
Kostis
Not 2010 but 2008, you have a link the package...
kostis57
Issue resolved by following your suggestion.
Thank you.
Kostis
Thank you.
Kostis
