Xnview MP Dark UI Enhancement
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
Moderators: XnTriq, xnview
Re: Xnview MP Dark UI Enhancement
Post by xnview » Wed Jun 20, 2012 7:15 am
XnTriq wrote:
xnview wrote:Currently it's not possible, but please send me some icons, and i'll add a settings..
Is this going to be a skinning feature as in XnView Classic, Pierre?
In 0.51, you'll able to change icons
Moderator & Librarian
Post by XnTriq » Fri Jun 22, 2012 8:45 pm
xnview wrote:In 0.51, you'll able to change icons
Don't get me wrong, Pierre. I love the Mezich icons.
I'm just wondering if you have any plans to eventually (low to medium priority) extend this a feature so it would not only allow for switching the icon theme but also the color scheme and maybe even the “workspace” altogether (as previously discussed).
Post by xnview » Mon Jun 25, 2012 1:45 pm
arabtornado wrote:How can i change close tabs icons (the X mark on every tab) and also how to change the icons of the toolbar
Do you have the last version of the UI?
arabtornado
Post by arabtornado » Mon Jun 25, 2012 4:22 pm
Do you mean Xnview MP 0.51 ? If no then i don't really know what are you talking about
Post by xnview » Mon Jun 25, 2012 7:30 pm
arabtornado wrote:Do you mean Xnview MP 0.51 ? If no then i don't really know what are you talking about
Yes for 0.51 (UI style + icons)?
arabtornado
Post by arabtornado » Tue Jun 26, 2012 12:32 am
Yes i tested it and it works great, but i'm facing a problem with the (X) close button because i can't change it, i thought the it use this photo "min_close.png" so i edited it but it doesn't work.
Post by xnview » Tue Jun 26, 2012 6:54 am
arabtornado wrote:Yes i tested it and it works great, but i'm facing a problem with the (X) close button because i can't change it, i thought the it use this photo "min_close.png" so i edited it but it doesn't work.
Ok, currently not possible but send me the new icon, and i'll change that...
arabtornado
Post by arabtornado » Tue Jun 26, 2012 11:54 am
Thank you, here is it, hope you like it
http://www.mediafire.com/?3cy0bbb1vsl0ie3
This is a multi layer icon feel free to edit it if you like it
bif
Post by bif » Thu Sep 13, 2012 8:14 pm
arabtornado wrote:Actually what i meant by padding is the vertical alignment of the icons in the address/search toolbar
Here is an update, I Fixed some problems in the original post.
Image Image
and here is the style files
http://www.mediafire.com/?qhzewsxbq2z5wz5
I think I'm to dumb for this...
I changed xnview.ini and ./UI/style_sheet_win.qss + ./UI/style_sheet.qss with the ones in your download link but my layout doesn't look any close like yours?
EDIT: Found it :)
Post by xnview » Mon Sep 17, 2012 6:41 am
Do you have now a good theme?
szelma
Post by szelma » Tue Jan 22, 2013 7:39 pm
hi all!
can somebody explain me how to install this UI? im a new user of xnview and have no idea how to do it. thanks very much.
szelma
Post by szelma » Sun Jan 27, 2013 5:53 pm
i replaced .ini file (...\AppData\Roaming\XnViewMP) and qss 2 files (C:\Program Files\XnViewMP\UI) from download link but nothing changed, can anybody help me please? the dark theme is brillint but i can see it only on attached screenshots - not on my computer :(
Post by XnTriq » Mon Jan 28, 2013 1:30 am
szelma wrote:can somebody explain me how to install this UI?
Welcome to the forum, szelma. I'm sorry you had to wait for a reply.
  1. Extract Dark+UI.rar and open style_sheet.qss & style_sheet_win.qss with a text editor. (You don't need the included xnview.ini.)
  2. Start XnView MP and go to View » Theme » Dark theme.
  3. Delete all text of the fields in the tabs titled style_sheet.qss & style_sheet_win.qss and replace it with the content of the downloaded QSS files.
  4. Exit the dialog by clicking on OK.
szelma
Post by szelma » Mon Jan 28, 2013 11:34 am
XnTriq, i did it, it looks great! Thanks very much.
orbspider
Post by orbspider » Sat Feb 09, 2013 3:21 am
I'm a bit late on this thread,
I found it searching the same problem as noted (and somehow solved) by arabtornado, how to change backgd color of PREVIEW panel
Quote XnTriq
a)
Tools » Settings... » Browser » File List » Item colours » Default color
b)
Tools » Settings... » Browser » Thumbnail » Appearance
c)
...style_sheet.qss ...» line #419
QListView {
background-color: #RRGGBB;
background-color: rgb(RRR, GGG, BBB);
this correctly describes how to
a) change color of thumbnail label bkgd,
b) thumbnails bkgd, and
c) thumbnail panel bkgrd
but not Preview bkgd, correct? So how do I do it, as my dark themes is looking good.
https://sites.google.com/site/debianins ... edirects=0
Another thing, how to change the selected thumbnail having blue-white box around it and the selected thumbnail label dark blue? I'd like to make them just maybe lighter grey. If that's Qt style sheet then where do I find those in Linux Debian?
Also, how do I change the white 1px line to left of each pane, as arabtornado doesn't have them? Not to mention the blue Tree folder icons and List folders (very yellow!)
Well, I already compared the css file in the Dark UI.rar with mine (in meld) and then I also put that one in place of mine, but preview is still white bkgd and still have 1px white lines at each pane inside-right and bottom border.
And, a request I very much suppose, the tag box/rating/colour on thumbnails would be nicer not white (ie grey) and the tag one especially not a "checked" box but just a colored "check" that shows if tagged or otherwise does not show.
Thanks e merci
