[Solved] 0.50 still problem with content location field
mahikeulbody
I installed 0.50 from scratch then I fullfilled several content location terms. After to save the picture, I do not see these informations. Moreover, I cannot anymore fullfill this field into the XMP/IPTC Editor, it is greyed.
Re: 0.50 (linux) still problem with content location field
How do you have added "content location"? If you use XMP, there are disabled...mahikeulbody wrote:I installed 0.50 from scratch then I fullfilled several content location terms. After to save the picture, I do not see these informations. Moreover, I cannot anymore fullfill this field into the XMP/IPTC Editor, it is greyed.
mahikeulbody
[solved] Re: 0.50 still problem with content location field
I probably added first the content location fields and then I choose 'XMP' mode before to save the picture...
Thanks for the explaination !
