6 seconds to show full interface?? Even with a clean .ini & .db?gendalf wrote:0.39 opened faster :/
in 0.50 interface shows fast but it takes about 6 seconds to show files/directories
XnViewMP 0.50
XnViewMP 0.50
gendalf
Re: XnViewMP 0.50
delete 0.39x64 directory, download 0.50x64, open 0.50x64.exe = laagsxnview wrote:6 seconds to show full interface?? Even with a clean .ini & .db?gendalf wrote: 0.39 opened faster :/
(win7x64)
ok now i downloaded 0.39 from some strange blog (because you deleted all links on old versions from 0.39 thread
Roumano
Re: XnViewMP 0.50
In my Linux machine, XnViewMP 0.50 is opening as fast as before (arround one second) ....
So it's very good.
If needed i have keep all my previous version ( 0.39 0.35 0.34 0.33 0.32 0.26) most are for 64bits.
So it's very good.
Re: XnViewMP 0.50
you have all versions here
http://download.xnview.com/old_versions/XnViewMP
I'll send a test version, i think that there is an issue in version of QT used...
