add extra space [SOLVED]
robjuffermans
Post by robjuffermans »
I'm trying to resize images with a fixed height and variable width to a certain ratio 1:sqrt(2). If the image is too width then I can crop it, but if it's too small how can I make the width bigger without stretching up the image? So I just want to add extra space.
Regards, Rob
Re: add extra space
do you have tried canvas resize?
robjuffermans
Re: add extra space [SOLVED]
Thank you very much, Pierre!
