I really like your program, I've been using it fow a while on Windows and Mac. When prompted to update I did but now the application crashes almost as soon as it is launched. I did find and delete the .xnviewmp folder, to no avail. Here are the crash reports with 0.39, 0.50 32 bit and 0.50 64 bit:
Process: XnViewMP [237]
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Symbol not found: _kCAContextPortNumber
Referenced from: /Applications/XnViewMP.app/Contents/MacOS/../Frameworks/QtWebKit.framework/Versions/4/QtWebKit
Expected in: /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
Process: XnViewMP [258]
Crashed Thread: 0
Dyld Error Message:
Process: XnViewMP [276]
Crashed Thread: 0
Dyld Error Message:
Symbol not found: _OBJC_CLASS_$_CALayerHost
Keep up the great work!
XnViewMP 0.50
Re: XnViewMP 0.50
Do you have downloaded the updated package from 13 june??
