"Always on top of other windows",
pseudo
Post by pseudo »
Bonjour Tout le monde
Dans XnView il y a l'option : "Toujours au dessus des autres fenêtres ", qui n'existe pas dans XnViewMP "
[Options/Interface/Fenêtres/Toujours au dessus des autres fenêtres "]
Est-il possible de la retrouver ?
Pour faire des Drag & Drop depuis un autre logiciel, il est pratique (en décochant cette option) que la fenêtre d'XnViewMp ne s'affiche pas au dessus.
Merci
Hello everyone
In XnView there is the option: "Always on top of other windows", which does not exist in XnViewMP "
[Options / Interface / Windows / Always on top of other windows "]
Is it possible to find it?
To make drag & drop from other software, it is convenient (by unchecking this option) XnViewMp the window is not displayed above.
thank you
Windows 11 et Windows 7 64 bit
Re: "Always on top of other windows",
Oui je dois rajouter cette option
budz45
Post by budz45 »
This would make a nice option yes.
But I would support an ability for "Always on top" to be temporarily work with any file open action that XnViewMP does so that the XnViewMP window always shows on top of any other program window(s) when I double-click on an associated file from Win Explorer.
(with "Only one instance of program" disabled)
ckit
Post by ckit »
I support this suggestion!
Currently using this option in XnView Classic and a custom INI file to show a single picture on top of other windows.
Markorki
Post by Markorki »
Good feature, even if it's necessary only for Windows...
Is XnView-MP intended to be the only XnView in the future ?
In operating systems such as linux or MacOS or any unix-like , the "always on top" feature is not an application feature, but a standard feature provided by the window manager of the system... I use it every day ;-)
Dommage, l'était sympa cette planète ;-(
