How to change comment?
venpa
how can I change the comment of the photo automatically?
Re: CHANGE THE COMMENT
Which comment?
venpa
For example, when I save with the GIMP photo software allows me to write a comment.
I should write one in automatic
So the embedded comment, in XnView you have 'edit comment'venpa wrote:For example, when I save with the GIMP photo software allows me to write a comment.
budz45
Hmmm, so I think the user means for a batch comment feature, correct?
Currently in the "Actions" of both XnConvert and XnViewMP 'Batch Convert' there is currently no method to batch write a a same embedded comment to multiple (supported) image files at the same time.
So the "Set comment" command could be also added to the Actions>Image for XnConvert/MP 'Batch Convert'
It's a good idea
It's a good idea
