Hi, I find the possibility to rename a file by inserting dates (modified - access -..) very useful.
But I have a question concerning the format of the dates inserted:
- actual format is : dd-mm-yyyy . This causes a problem by sorting files because the first value is the day of the month.
I SUGGEST to have the possibility to insert the dates with the format yyyy-mm-dd (or even without "-" !).
Many thanks solong!
File Rename with Date Format yyyy-mm-dd
Re: File Rename with Date Format yyyy-mm-dd
You can change the format of the date with <Date [Y-m-d]>
LightOker
Thanks a lot. That works !
