0.51: two problems, crash and a bad view
cortopastito
Post by cortopastito »
* i find a problem when i open a image with double click and the image not appear in full screen then i press middle button , but is
xnview mp don't start in full screen and still it was carrying was going to full screen, then the program crash !!! exception code = c0000005
* and other problem is when i see a picture from 1x.com for example size=774x640 in my resolution 1360x768 the picture is stretched and appears wrongs bar on the sides
I really like the rest!!
thanks and good job!
Re: two problems, crash and a bad view in xnview mp 0.51
cortopastito wrote:* i find a problem when i open a image with double click and the image not appear in full screen then i press middle button , but is
On which OS?
Could you send me a sample file?
cortopastito
the os is win 7 and the picture for example is http://imghost.1x.com/18846.jpg.
This problem occurs occasionally when you open the image with double click , but always when you change the images in full screen, then i recommend you download two images, or try it with other images. this problem happens always on full screen and with pictures that need stretch.
regards.
cortopastito wrote:the os is win 7 and the picture for example is http://imghost.1x.com/18846.jpg.
Is it possible to take a screenshot of the problem?
