Two Problems with Panasonic GH2
andrewj
Post by andrewj »
I've just bought a Panasonic GH2, and I'm having a couple of problems.
First, XnView doesn't display all the EXIF data for the RW2 files. The "Camera" section is almost empty and the "Makernotes" do not display for the RW2. They are fine for the JPGs. If I use exiftool both appear to be fully populated.
Second, and most immediately a problem, batch rename using the file date doesn't work for the RW2 files. This has never been a problem for any of my Canon cameras. I get an output filename where the date part is just omitted.
Does anyone know what tag is used to drive the date function in batch rename? This would help me to explore the problem a bit further.
Thanks
Andrew
Re: Two Problems with Panasonic GH2
could you send me a sample, please?
andrewj
Post by andrewj »
Hi Pierre,
I'll PM a sample file later today.
Re my last question, can you tell me what data you read from the file to drive the date for batch rename?
Thanks
Andrew
Ok, i'll try to add the support
XnView use EXIF date
andrewj
Post by andrewj »
Thanks. My Canon RAWs have three Exif Dates:
ModifyDate
DateTimeOriginal
CreateDate
Do you know which one you use?
Thanks
Andrew
You can use these 3 exif dates
andrewj
Post by andrewj »
I've fixed the renaming problem. For some reason (probably related to the EXIF display problem) the simple "Date" template doesn't work with RW2 files. However, the alternative "Date Taken" seems to work fine.
The limited display of EXIF data is a nuisance, but not a major problem, so can take its place on the "to fix" list.
Thanks for your help,
Andrew
