Layout - Dark Theme status bar
ElQuia
Post by ElQuia »
Hi.
First: thanks Pierre for your excelente work.
My problem, please see attached screen. AS you see I have a tight 16x9 thumbs layout. But to get it that way I had to edit the ini manually and enter:
[Appearance]
thumbWidth=264
thumbHeight=149
It would be nice having an option to resize thumbs to desired proportion (aka 16:9, 16:10 , etc) with out editing ini???
2nd: please see the status bar, in the dark theme fonts in status bar are not visilbe they are in other themes.
again, thanks
:D
EDIT: sorry, it is mp 051 x86 AND x64 (both the same problems) on windows 7 x64
Hey.....anybody? :( :shock: :(
"Death smiles at us all. All a man can do is smile back" - "No hay Camino hacia la libertad. La Libertad es el camino."
Re: Layout - Dark Theme status bar
ElQuia wrote: It would be nice having an option to resize thumbs to desired proportion (aka 16:9, 16:10 , etc) with out editing ini???
You would like to enter a proportion and a width, right?
You have changed something in the theme?
ElQuia
Post by ElQuia »
xnview wrote:You would like to enter a proportion and a width, right?
Right, I have 2 big folders with pictures, one are all 16:9 others are in various formats. it would be nice having an gui option to set proportion and thumb size for each folder
No I have not changed anything (that I am aware of :-( ), attaching the xnview.ini of mp 0.51 x64:
[Start]
toolbar=default.bar
shortcut=default.keys
geom=@ByteArray(\x1\xd9\xd0\xcb\0\x1\0\0\xff\xff\xff\xfc\xff\xff\xff\xfc\0\0\x6\x43\0\0\x3\x87\0\0\0\xf2\0\0\0\x17\0\0\x6?\0\0\x2\xf9\0\0\0\0\x2\0)
RecentFiles=F:/Pictures/WallPapers/! Selected/10 3.jpg, F:/Pictures/WallPapers/! Selected/2.jpg, F:/Pictures/WallPapers/! Selected/001 (24).jpg, F:/Pictures/WallPapers/! Selected/0048.jpg, F:/Pictures/WallPapers/! Selected/47 1.jpg, F:/Pictures/WallPapers/! Selected/2 2.jpg, F:/Pictures/WallPapers/! Selected/__Red_____wide_wallpaper_by_V_ace.jpg
OpenWith=@Invalid()
OpenWithName=@Invalid()
PathBrowser=F:/Pictures/WallPapers/! Selected/
History=F:/Pictures/WallPapers/! Selected/, F:/Pictures/WallPapers/Nature/, F:/Pictures/WallPapers/Nature/Beaches/, F:/Pictures/WallPapers/Nature/Animales/, F:/Pictures/WallPapers/Nature/Animales/Wolfs/, F:/Pictures/WallPapers/Nature/Animales/Reptiles/, F:/Pictures/WallPapers/Nature/Animales/Ocean Life/Wide/, F:/Pictures/WallPapers/Nature/Animales/Ocean Life/, F:/Pictures/WallPapers/Nature/Animales/Insects Close Ups/, F:/Pictures/WallPapers/Nature/Animales/Insects/, "F:/Pictures/WallPapers/Nature/Animales/Dolphins, sharks and whales/", F:/Pictures/WallPapers/Nature/Animales/Dolphins/, F:/Pictures/WallPapers/Nature/Animales/Caballos/, F:/Pictures/WallPapers/Nature/Animales/Birds/, F:/Pictures/WallPapers/Nature/Animales/Ballenas Sur Argentino/
startupType=1
customPath=
startInFull=true
startBrowser=true
oneInstance=true
otherFlag=0
otherFolder=
style=1
lastCheck=@Variant(\0\0\0\xe\0%z\x83)
updater=3
singleView=false
dbFlag=0
dbFolder=
language=en
session=@Invalid()
sessionIdx=0
[Browser]
size=@Size(1600 859)
state=@ByteArray(\0\0\0\xff\0\0\0\0\xfd\0\0\0\x1\0\0\0\0\0\0\x1\x3\0\0\x3\x18\xfc\x2\0\0\0\x3\xfb\0\0\0\xe\0\x66\0i\0l\0t\0\x65\0r\0\x44\0\0\0\0\0\xff\xff\xff\xff\0\0\0\0\0\0\0\0\xfc\0\0\0\x30\0\0\x3\x18\0\0\0\0\0\xff\xff\xff\xfa\xff\xff\xff\xff\x2\0\0\0\x3\xfb\0\0\0\xe\0\x66\0o\0l\0\x64\0\x65\0r\0\x44\0\0\0\0\0\xff\xff\xff\xff\0\0\0R\0\xff\xff\xff\xfb\0\0\0\x12\0\x66\0\x61\0v\0o\0r\0i\0t\0\x65\0\x44\0\0\0\0\0\xff\xff\xff\xff\0\0\0\x19\0\xff\xff\xff\xfb\0\0\0\x12\0\x63\0\x61\0t\0\x65\0g\0o\0r\0y\0\x44\0\0\0\0\0\xff\xff\xff\xff\0\0\0\x19\0\xff\xff\xff\xfc\0\0\x1\xbe\0\0\x1\x8a\0\0\0\0\0\xff\xff\xff\xfa\0\0\0\x1\x2\0\0\0\x2\xfb\0\0\0\n\0p\0r\0\x65\0v\0\x44\0\0\0\0\0\xff\xff\xff\xff\0\0\0\x19\0\xff\xff\xff\xfb\0\0\0\x16\0P\0r\0\x65\0v\0i\0\x65\0w\0\x44\0o\0\x63\0k\x2\0\0\0\x4\0\0\x1\xdf\0\0\x5-\0\0\x1\t\0\0\x6@\0\0\x3\x18\0\0\0\x1\0\0\0\x2\0\0\0\x1\0\0\0\x2\xfc\0\0\0\x1\0\0\0\x2\0\0\0\x1\0\0\0\x12\0T\0o\0o\0l\0\x42\0\x61\0r\0 \0\x31\x1\0\0\0\0\xff\xff\xff\xff\0\0\0\0\0\0\0\0)
header="@ByteArray(\0\0\0\xff\0\0\0\0\0\0\0\x1\0\0\0\0\0\0\0\0\x1\0\0\0,\0\0\0\x1\0\0\0\0\0\0\0\x2\0\0\0\x3\0\0\0\x4\0\0\0\x5\0\0\0\x6\0\0\0\a\0\0\0\b\0\0\0\t\0\0\0\n\0\0\0\v\0\0\0\f\0\0\0\r\0\0\0\xe\0\0\0\xf\0\0\0\x10\0\0\0\x11\0\0\0\x12\0\0\0\x13\0\0\0\x14\0\0\0\x15\0\0\0\x16\0\0\0\x17\0\0\0\x18\0\0\0\x19\0\0\0\x1a\0\0\0\x1b\0\0\0\x1c\0\0\0\x1d\0\0\0\x1e\0\0\0\x1f\0\0\0 \0\0\0!\0\0\0\"\0\0\0#\0\0\0$\0\0\0%\0\0\0&\0\0\0'\0\0\0(\0\0\0)\0\0\0*\0\0\0+\0\0\0,\0\0\0\x1\0\0\0\0\0\0\0\x2\0\0\0\x3\0\0\0\x4\0\0\0\x5\0\0\0\x6\0\0\0\a\0\0\0\b\0\0\0\t\0\0\0\n\0\0\0\v\0\0\0\f\0\0\0\r\0\0\0\xe\0\0\0\xf\0\0\0\x10\0\0\0\x11\0\0\0\x12\0\0\0\x13\0\0\0\x14\0\0\0\x15\0\0\0\x16\0\0\0\x17\0\0\0\x18\0\0\0\x19\0\0\0\x1a\0\0\0\x1b\0\0\0\x1c\0\0\0\x1d\0\0\0\x1e\0\0\0\x1f\0\0\0 \0\0\0!\0\0\0\"\0\0\0#\0\0\0$\0\0\0%\0\0\0&\0\0\0'\0\0\0(\0\0\0)\0\0\0*\0\0\0+\0\0\0\0\0\0\0\0\0\0\x11\x30\0\0\0,\x1\x1\0\x1\0\0\0\0\0\0\0\0\0\0\0\0\x64\xff\xff\xff\xff\0\0\0\x81\0\0\0\0\0\0\0\x1\0\0\x11\x30\0\0\0,\0\0\0\0)"
header2=false
Tab=4294967289
tagReset=3
rotationKeepDate=true
rotationChangeExif=false
rotationUseLossless=true
openAction_0=2
openAction_1=2
openAction_2=2
openAction_3=1
openAction_4=2
openAction_5=1
openAction_6=1
viewAs=0
statusBar=true
smallToolBar=true
showPaneTitle=true
vTabs=true
sort=0
sortOrder=0
showHiddenFiles=false
showCompanionFiles=true
filter=4
customFilter=3703
thumbnailFilter=3669
custom1Ext=htm, html, mht, mhtml, xml, xhtml, eml, nws, url, svg, svgz
custom2Ext=
sizeInBytes=false
tooltips=<b>{Filename}</b><br>{Modified Date} - {Date taken}<br>{Size KB} Kib
useTooltips=true
layout=-1
use4Thumb=true
m_folderColor1=255 255 170
m_folderColor2=255 200 74
m_folderColor3=197 140 0
m_folderColor4=250 210 105
m_folderColor5=172 140 53
prevBackColor=0 0 0
catMatchAll=false
searchFlags=6
onTheFly=false
selectOnEnterFolder=true
toolBar=true
delayedPreview=true
mixFileFolder=false
newFilesAtBottom=false
use4VideoThumb=true
keyDelayedPrev=false
[Preview]
info=@ByteArray(\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1)
tabs=true
vTab=65534
prevDocked=false
[Load]
useEmbeddedThumb=false
useOrgIfSmaller=true
useHighQuality=true
useSharpen=true
sharpen=50
useGamma=true
gamma=1
noReadError=false
useEXIFRotation=true
useEXIFDpi=true
composeWithTrans=false
composeWithAlpha=false
useICCProfile=false
ICCDefault=0
ICCIntent=0
ICCProfile=
ICCDefaultProfile=
RAWFlag=0
RAWAutoBalance=false
RAWCameraBalance=true
RAWGamma=@Variant(\0\0\0\x87?\x80\0\0)
RAWBrightness=@Variant(\0\0\0\x87?\x19\x99\x9a)
RAWRedScaling=@Variant(\0\0\0\x87?L\xcc\xcd)
RAWBlueScaling=@Variant(\0\0\0\x87?\x80\0\0)
PCDBase=2
GrobBpp=0
DjVuMaxDpi=false
WMFHighRes=false
PDFDpi=72
PDFPageSize=0
ICOIn32bits=false
PDDPage=0
EXRGamma=@Variant(\0\0\0\x87?\x80\0\0)
HDRGamma=@Variant(\0\0\0\x87?\x80\0\0)
YUVWidth=720
YUVHeight=576
YUVOffset=0
RAWWidth=256
RAWHeight=256
RAWOffset=0
channelOrder=0
channelType=1
videoFrameP=10
RAWAutoBrightness=true
PDFCIE=false
RAWBpp=24
[Save]
addExtensionIfNeeded=true
keepOriginalDate=true
JPEGQuality=80
JPEGProgressive=false
JPEGOptimizeHuffmanTable=false
JPEGKeepEXIF=true
JPEGKeepIPTC=true
JPEGRebuildThumb=true
useOriginalJPEGQuality=false
JPEGDCTMethod=0
JPEGSubSampling=0
JPEGSmoothFactor=0
WebPQuality=80
PNGCompressionLevel=6
PNGInterlaced=false
PNGFilter=0
GIFInterlaced=false
GIF87aHeader=false
IFFCompress=false
PCXCompress=false
TGACompress=false
TGABottomUp=false
SOFTCompress=true
SGICompress=true
BMPCompress=false
OS2Header=false
HP49Header=false
PPMInAscii=false
TIFFCompress=0
TIFFBinaryCompress=0
TIFFOnlyOneStrip=false
DPXMsbf=false
PDFCompress=0
PDFJpegQuality=80
JP2KMode=0
JP2KQuality=80
JP2KRatio=4
JP2KFileSize=100
JPEGKeepXMP=true
keepEXIF=true
keepIPTC=true
keepXMP=true
keepICC=true
JpegXRQuality=80
JpegXRColorFormat=0
JpegXRFilter=0
WebPFileSize=128
WebPMethod=0
TIFFQuality=80
[Appearance]
thumbWidth=264
thumbHeight=149
useLabelSpacing=false
labelAlign=1
labelFont=@Variant(\0\0\0@\0\0\0\x1c\0M\0S\0 \0S\0h\0\x65\0l\0l\0 \0\x44\0l\0g\0 \0\x32@ \x80\0\0\0\0\0\xff\xff\xff\xff\x5\x1\0\x32\x10)
overlayIcons=0
itemSpacing=0
useShadow=false
borderSize=0
borderColor=172 172 172
useThumbBackColor=true
thumbBackColor=0 0 0
thumbBorderSize=0
thumbBorderColor=255 255 255
thumbPadding=0
showFilename=false
customLabel-1={Focal Length}mm f/{F-Number} {Exposure Time}s {ISO Value}iso
customLabel-2={Width}x{Height} - {Size KB}
customLabel-3=
customLabel-4=
customLabel-5=
defaultLabelColor=0 0 0
defaultLabelBColor=210 210 210
thumbLabels=
formatColor-0="[jpeg],237 237 202,0 0 0"
formatColor-1="[gif],220 235 220,0 0 0"
formatColor-2="[png],232 222 220,0 0 0"
formatColor-3="[bmp],227 227 255,0 0 0"
formatColor-4="[tiff],192 197 235,0 0 0"
formatColor-5="[tga],230 255 255,0 0 0"
formatColor-6="[iff],247 235 235,0 0 0"
formatColor-7="[sgi],247 237 242,0 0 0"
formatColor-8="[pcx],235 230 230,0 0 0"
formatColor-9="[psd],255 255 227,0 0 0"
formatColor-10="[pcd],235 215 235,0 0 0"
formatColor-11="[psp],237 208 163,0 0 0"
formatColor-12="[pict],202 202 255,0 0 0"
formatColor-13="[xpm],242 227 227,0 0 0"
formatColor-14="[xbm],216 216 216,0 0 0"
formatColor-15="[pbm],191 191 182,0 0 0"
formatColor-16="[pgm],207 207 197,0 0 0"
formatColor-17="[ppm],235 225 159,0 0 0"
formatColor-18="[ras],255 255 227,0 0 0"
formatColor-19="[wmf],187 187 187,0 0 0"
formatColor-20="[emf],212 212 212,0 0 0"
formatColor-21="[ico],217 247 227,0 0 0"
formatColor-22="[cur],217 247 227,0 0 0"
formatColor-23="[ani],217 247 227,0 0 0"
formatColor-24="[fpx],229 255 255,0 0 0"
formatColor-25="[jp2],237 237 202,0 0 0"
selectedColor=10 36 106
[DB]
thumbInDB=true
folder=@Invalid()
cacheComp=1
excludeRemovable=true
excludeCD=true
basePath=F:/Pictures/
useMaxCache=false
maxCache=100
folderFlag=@Invalid()
[Keywords]
import=true
export=false
applyParent=false
readHierarchical=true
characters=0
[XMP]
xmpRating=false
xmpLabel=false
xmpComment=false
[IPTC]
defaultCodec=0
utf8Save=false
[Viewer]
adjustZoomDpi=true
ratio=0
fit=1
useAnimation=true
viewFilter=3669
readAhead=true
cacheBehind=true
zoomQuality=1
loop=false
slideDelay=2000
slideDir=0
backColor=0 0 0
fullBackColor=0 0 0
infoTemplate=
infoBackColor=255 255 127
infoColor=0 0 0
infoOpacity=70
infoFont=@Variant(\0\0\0@\0\0\0\x1c\0M\0S\0 \0S\0h\0\x65\0l\0l\0 \0\x44\0l\0g\0 \0\x32@ \x80\0\0\0\0\0\xff\xff\xff\xff\x5\x1\0\x32\x10)
infoPosition=0
useChecker=true
checkerColor1=255 255 255 255
checkerColor2=240 240 240 255
checkBoardSize=8
useBorderLine=false
borderLineColor=0 0 0
hideScrollbar=true
useGamma=false
gamma=1.2
useZoom=false
zoomFixed=10
zoomRelative=1.41421356
prevSize=@Size(160 120)
iconSnapshot=false
multipleView=false
oneTab=false
lastTab=false
buttonAction=1
wheelAction=0
statusBar=true
toolBar=true
inchPrintSize=false
usePan=true
histoState=@ByteArray(\0\0\0\x1\0\0\0\0\x4\0\0\0\x80\x1\x1\xff\xff\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0)
panSize=@Size(90 90)
usePlaybar=true
full2Monitor=true
full2HideTB=true
defaultFormat=@ByteArray(png)
lButtonAction=1
lButtonCtrlAction=2
rButtonAction=0
mButtonAction=-1
rButtonCtrlAction=-1
full2HideSB=true
fullFloatView=true
autoPlay=true
saveFolder=
maxViewTab=99
lKeyLR=0
lKeyUD=0
lockZoom=false
videoPlaybar=true
[Format]
ps=ps ai epsf pdf eps
text=cpp c++ txt css ini php pas c h js cc
avi=mts divx asf rm wmv avi vob vfw mkv
qt=3gp mov 3g2 qt 3gp2
mpeg=m2v mpeg mpa mpe mpg mpm m1s m1v
audio=mp+ mp2 mp3 mp4 aif ogg wav mpc asx mpp mid wma au rmi snd
archive=zip tgz arj tar rar gz
[%General]
allFormats=false
useRecycleBin=true
confirmDel=true
selectNewFiles=true
useCopyOf=true
useTabs=true
tabsOnBottom=false
tabWidthMax=20
tabClose=true
tabThumb=0
sync=true
maxRecent=20
purgeRecent=false
dblMode=1
midMode=0
enterMode=1
showAgain=0
savingKeepDate=true
TemplateList=@Variant(\0\0\0\b\0\0\0\x1\0\0\0\b\0N\0o\0n\0\x65\0\0\0\n\0\0\0\0)
confirmSave=true
tabMax=0
tabDoubleClick=1
[ResizeDlg]
geometry=@ByteArray(\x1\xd9\xd0\xcb\0\x1\0\0\0\0\x2\x9a\0\0\0\xe5\0\0\x3\xa5\0\0\x2\x9d\0\0\x2\x9e\0\0\0\xfc\0\0\x3\xa1\0\0\x2\x99\0\0\0\0\0\0)
presets=@Variant(\0\0\0\b\0\0\0\x1\0\0\0\x16\0<\0L\0\x61\0s\0t\0 \0U\0s\0\x65\0\x64\0>\0\0\0\f\0\0\0\x32\0\0\0\x1\0\0\x6@\0\0\x3\x8d\x1\0\0\0\0@0\0\0\0\0\0\0@\".\x14z\xe1G\xae@Y\0\0\0\0\0\0\0\0\0\x1\0\0\0\0\x1)
[Settings]
geometry=@ByteArray(\x1\xd9\xd0\xcb\0\x1\0\0\0\0\x2#\0\0\0\xe3\0\0\x4\xc0\0\0\x3\x4\0\0\x2'\0\0\0\xfa\0\0\x4\xbc\0\0\x3\0\0\0\0\0\0\0)
cacheList=@ByteArray(\0\0\0\xff\0\0\0\0\0\0\0\x1\0\0\0\x1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\x1\xb2\0\0\0\x3\x1\0\0\x1\0\0\0\0\0\0\0\0\0\0\0\0\x64\xff\xff\xff\xff\0\0\0\x81\0\0\0\0\0\0\0\x2\0\0\0\xc8\0\0\0\x2\0\0\0\0\0\0\0\xea\0\0\0\x1\0\0\0\0)
[Export]
geometry=@ByteArray(\x1\xd9\xd0\xcb\0\x1\0\0\0\0\x1\xe9\0\0\0\xbc\0\0\x4W\0\0\x2\xb5\0\0\x1\xed\0\0\0\xd3\0\0\x4S\0\0\x2\xb1\0\0\0\0\0\0)
auto=false
current=0
[ExportSettings]
keepEXIF=true
keepIPTC=false
keepXMP=false
keepICC=false
JPEGQuality=80
JPEGDCTMethod=0
JPEGSubSampling=0
JPEGSmoothFactor=0
WebPQuality=80
JpegXRQuality=80
JpegXRColorFormat=0
JpegXRFilter=0
PNGInterlaced=false
PNGFilter=0
GIFInterlaced=false
GIF87aHeader=false
IFFCompress=false
PCXCompress=false
TGACompress=false
TGABottomUp=false
SOFTCompress=false
SGICompress=false
BMPCompress=false
OS2Header=false
HP49Header=false
PPMInAscii=true
TIFFCompress=0
DPXMsbf=true
PDFCompress=0
PDFJpegQuality=1225832
JP2KMode=0
JP2KQuality=80
JP2KRatio=4
JP2KFileSize=100
ElQuia wrote: No I have not changed anything (that I am aware of :-( ), attaching the xnview.ini of mp 0.51 x64:
Strange, on 0.51 here is the default dark theme on Win7
ElQuia
Post by ElQuia »
Here is my status bar (see attach). I have a personalized windows theme, THAT is the culprit, don´t know why :?: :?: :?:
If I revert to any default aero theme XNView MP reverts to normal status bar
EDIT: Standard XNView does NOT have problems with status bar on same 7 theme....
EDIT2: MP only has this problem with dark theme. NOT with any other. The same happens with x86 and x64 MP. ..... :bug: :?:
