I've noticed a strange UI behavior that I can reproduce;
1) Go with browser into a folder
1.a) open some image from it in a new tab
1.b) while staying on the tabbed image (not the browser!) I browse with mouse-wheel through the pictures
2.) leave last picture watched open and switch to browser with folder view
2.a) browse through home/pictures or a different folder with images
2.b) open up a different picture in one of these folders
2.c) browser through pictures or folder with mouse wheel
2.d) close opened picture of this folder, leave browser open, stay in folder with browser
2.e) switch to still opened last picture of (1.b)
2.d) close last picture of (1.b)
3) browser resets back to view of the folder in (1) with last image of (1.b) selected
This also happens when the last picture of (1.b) is closed before the picture in (2.d), too
Erasing the cache file resets the app and resolves the matter until next time.
Additionally: I observed that the menu-bars became unselectable at some point once (they didn't move), but I don't know what caused this - Only mouse wheel scrolling through browser worked. Restarting the app fixed this for me.
(I can add some screenshots if that helps.)
0.51 OSX: Strange UI behavior
Schattenreiter
HackIntosh
Mountain Lion 10.8.2 • G530 • GA-Z77M-D3H • Sapphire 5770 • Soundblaster Audigy Platinum • 16GB-1333-DDR3 • Atheros AR9280
Schattenreiter
Re: 0.51 OSX - Strange UI behavior
Found another version of the above;
1) Go into a folder (in this case /home/pictures)
2) Open up an image from it in a tap
2.a) leave image open
3) select browser-tab and go to a different folder
3.1) browse through it
3.2) stay with browser view in that folder
4.) close the picture of (2.a)
5.) close xnview
6.) open xnview
6.a) browser view as in (3.2) is restored BUT the previously closed picture of (2.a) is automatically opened up again in a tab again, too!
This also happens when the tabbed picture is closed early on and xnview is used for some time with other tabbed images and browsing, and etc. and then closed and reopened again.
Erasing the cache file solves the problem.
5.) close xnview
6.) open xnview
HackIntosh
What's the problem, when you close picture view, browser is synchronized with this imageSchattenreiter wrote: 3) browser resets back to view of the folder in (1) with last image of (1.b) selected
Yes, normal if you have saved the session6.a) browser view as in (3.2) is restored BUT the previously closed picture of (2.a) is automatically opened up again in a tab again, too!
