XnView would not remember that window was maximized. If I start with a file (start in fullscreen is on) and then leave fullscreen, window will be small and in the top left corner. If I resize it before closing, next time I launch a file the window will be of a new size. However, maximizing window before leaving has no effect on the next launch, as it will open in a not-maximized window.
If I start using .exe, it will remember maximized state correctly, however next launch from file resets size and position to a small window in the top left corner.
Unchecking "Fullscreen when starting with a file" solves the problem but is not very convenient.
Problem persisted from early builds.
Windows 7x64, UAC off
0.51 Win7: Window maximized state
xankazo
Re: XnView 0.51, Window maximized state
Yeah, I can confirm this.
kufer
Create a shortcut to xnview.exe anywhere in system and edit it to run program maximized. Then run it and close it.
From now it will remember last state as maximized.
Worked for me
Worked for me
Re: 0.51: Window maximized state
I can't reproduce with 0.51.
* start xnview with a file (open in fullscreen)
* ESC, and here the size is not correct???
Rebellious
Re: 0.51 Win7: Window maximized state
Same problem here, v0.51Linux-64, though It worked ok sometimes . If app is maximized then closed, when app reopens treeview window width is not restored. Seems to have something to do with starting with command line. If app is not maximized (restored) the control size is restored properly on startup.
CreativeWorld
Same problem on 0.61 / Win8.1 x64.
It remembers the window position and size, but maximized state seems to be ignored completely. Happens only with the described scenario after fullscreen > view mode transition - the resulting window is never maximized. Browser mode doesn't have this issue.xnview wrote:* start xnview with a file (open in fullscreen)
