IPTC and overall review
yester64
Post by yester64 »
I was a long time Acdsee Pro user and since my version was 2.5 and i did not want to spend another $100 Dollars on an upgrade, i was looking around and found this software.
Got to say that i love it. If i just knew earlier.
This MP version is just like Acdsee and its so easy to understand (i hope). So far i have no complaints.
There is only one thing, maybe i was overlooking it, but i was not able to delete a keyword in a couple of pictures. There is one way to delete the keyword individually or to clean all fields. So now i like to ask if i overlooked it and you can delete it to all images or via a batch.
And i will make a donation very soon. Really. I am just so happy right now with the software. (also the 64bit support, great)
Thanks and hope you continue to develop.
Vapavite123
Re: IPTC and overall review
Post by Vapavite123 »
Not for keywords and categories Extra :?
This is the major disadvantage in relation to this module that would otherwise be very powerful. :(
Frenche :
Non pour les mots clés et Catégories Supplémentaire :?
C'est l'inconvénient majeur en ce qui concerne ce module qui serait sinon très performant. :(
Yes, currently i don't know how to make the 'delete keyword' easily? Do you have an idea?
mahikeulbody
Post by mahikeulbody »
Je pense que Exiftool peut faire ça très facilement. Il faut "juste" que XnViewMP l'invoque avec la bonne commande, en lui passant la liste des fichiers concernés.
D'une façon plus générale, ce serait génial si XnViewMp avait un mode "avancé" semblable à ExiftoolGUI (qui ne tourne malheureusement que sur Windows).
