I set the Location field = "home" using the IPTC/XMP Editor (XMP only mode)
XMP panel displays :
- Iptc4xmpCore.Location file : home
- photoshop.Location : home
and Exiftool panel displays twice Location fields, both with "home" value.
It seems to me it should have only one Location field (the Iptc4xmpCore one). Probably XnViewMp should update the exiftool version used since the current one is a little bit old (8.63 when the latest version is 8.96).
Edit: I confirm that Exiftool 8.96 displays only one Location field.
0.51 : location value duplicated (XMP)
Re: 0.51 : location value duplicated (XMP)
ok, i'll update exiftool
wmw
Hello,xnview wrote:ok, i'll update exiftool
XNviewMP 0.61 from Jul. 18, 2013 still has ExifTool v. 8.96 - uptodate version is 9.34...
Is it possible to users to update ExifTool themselves?
Regards,
WMW
yeswmw wrote: Is it possible to users to update ExifTool themselves?
wmw
OK, so I will copy new ExifTool into the AddOn folder...xnview wrote:yeswmw wrote: Is it possible to users to update ExifTool themselves?
Thank you !
oops66
Hello,wmw wrote:...XNviewMP 0.61 from Jul. 18, 2013 still has ExifTool v. 8.96 - uptodate version is 9.34...
... Even if the user can update Exiftool ... sometime Xnview should also integrate a major change version of Exiftool.
