0.51 cbr/cbz folder crash
Brisq
Post by Brisq »
Win7 x64
When opening a folder with cbr/cbz files in it, xnview sometimes crashes. Crash doesn't seem to be caused by a specific file, as sometimes it does not occur on the same file/folder it crashed before. Perhaps related is the fact that previews generate only on about half of the files viewed.
Crash occurs in about 90% cases on x64 version and only sporadically on x32. Previews generate normally on x32. (x32 was launched under x64 system).
Crash does not happen if option to select first file in folder is disabled, even if files are selected manually after.
Re: 0.51 cbr/cbz folder crash
do you have a folder where you can reproduce the crash...
