suggestion: remember selected exif entry between images
rmtk
Post by rmtk »
Occasionally I want to compare an exif value between two or more images. I scroll down the exif or exiftool pane to select an entry, but when I click the next image, xnviewmp forgets the selected entry and the pane scrolls up to the top. This condition can be quite inconveniet as an image may contains one hundred or more exif entyirs and difficult to identify a specific one.
Thanks in advance.
Markorki
Re: suggestion: remember selected exif entry between images
Post by Markorki »
I agree, and this would be nice for all the info tabs, except of course histogram.
And (should i start a new topic ?), I would like to have too a memory effect ("keep values") between calls to the "adjust levels" function , just as in Windows XnView, and even for most of possible adjustments (contrast, gamma, etc...)
Dommage, l'était sympa cette planète ;-(
Display of the last used values and settings when a dialog box is opened would be useful in general, as the same settings will often be used repetitively.
Markorki wrote:And (should i start a new topic ?), I would like to have too a memory effect ("keep values") between calls to the "adjust levels" function , just as in Windows XnView, and even for most of possible adjustments (contrast, gamma, etc...)
yes please
