Maybe a glitch? I'm getting a small grey box in the top left corner of the screen when viewing any file in fullscreen mode. Screenshot attached with red arrow added. I'm using v0.51 on Win 7, 32 bit.
Great program, by the way.
0.51 win7: grey box in top left of fullscreen view
- Attachments
- Screenshot.jpg (99.08 KiB) Viewed 2436 times
Re: 0.51 win7: grey box in top left of fullscreen view
what do you have in option>View>Info - Information displayed?
You're right - it's the info box. I've cleared the "information displayed" in the options you mentioned because I don't want any info display.
If I press the "I" shortcut while in fullscreen the box disappears. But it re-appears each time I go back to fullscreen mode again. Is there any way to permanently turn off the info display?
currently no way, but if info is empty, the box must not be visible... I'll fix it
In v0.84 there is a setting "Show Info" in Settings » View » Fullscreen to show/hide the info.
Closed
