I just install XnView on my mac osx lion and the quality of thumb is not very good. I difficult to see the picture. I look at the options to see if it's possible to chose the quality. Yes, It's possible but it never change the quality of thumb. Have you a solution.
Thank you
Quality of thumb
Re: Quality of thumb
Could you post a screenshot?
netgus
You can see one picture with the top image blur and down the same image in preview, but net
strange, could you send me a picture file sample?
- Forum Librarian
Is the option Use embedded thumbnail in Settings » Browser » Thumbnail » Misc enabled?
Vapavite123
Normal voir l'icône "Vignette intégrée"
http://newsgroup.xnview.com/viewtopic.p ... t=vignette
Je te cite Pierre :
Nonxnview wrote:strange, could you send me a picture file sample?
Je te cite Pierre :
Bien à vousOui la dessus je ne suis pas très clair
Actuellement l'icône est bien mise si la vignette intégrée est utilisée. Logique, pas logique??
