Very slow moving
lian
Very slow moving
I've got a problem of speed with moving or copying files. When I click on Alt+M to move an image, the menu appears and when I try to choose a new folder for destination, it tooks nearly one minute before the chosen directory is selected (MP is just hanging). I thought because it was the hudge numbers of files I've got in some folders but I discovered XnView 1.99 has not this problem and it's much more convenient to move files with it.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: Very slow moving
When you open destination dialog (Alt+M), on 1.99 it's quick, and very slow on XnViewMP?
Do you have the same list in the 2 versions? Do you have network drives?
lian
No network drive. Well, after some tests: if the destination folder is hudge, the problem is the same for XnView 1.99. If it's not too big, it goes faster than MP because MP, whatever folder I want to move my pictures, hangs on. After one move, there is no problem to move other files. It's just the first move after starting the computer what gives "problem".
you means that it's 'opening the dialog is slow'?
lian
Opening the dialog is correct. It's when clicking on "Move" or selecting another directory than the default one what initiates the hanging.
Ok, always or only the first time??lian wrote:Opening the dialog is correct. It's when clicking on "Move"
and not in XnView 1.99??or selecting another directory than the default one what initiates the hanging.
lian
Well, I make some other test - boring because I have to reboot the computer each time
If the target directory is heavy, it's slow in both cases but a little faster in Xn 1.99. So it seems to depend of the size of the target directory. Is is a way to solve this ?
Strange, how many files do you have in the folder?
lian
Kof kof... 20 000 files - my God ! Only illustrations and paintings... Well maybe I could classified them but it's more convenient to have them in one folder.
and in other software, do you have the same problem with this big folder?
lian
Hard to say but I have no problem with Fastone Image Viewer: moving files is very fast.
I move them with xplorer2 shortcuts too and it's fast.
But the directory tree is not shown, right??lian wrote:Hard to say but I have no problem with Fastone Image Viewer: moving files is very fast.
lian
In Fastone Image Viewer ? Or in XnMP ? In bot case the tree is not shown.
In XnMP, when you choose your big folder, the tree view is shown, no?lian wrote:In Fastone Image Viewer ? Or in XnMP ? In bot case the tree is not shown.
lian
You mean like in the screen capture attached here ?
