0.51 XP: Thumbnail not refreshed after rename, rotate
laufu
Post by laufu »
In BROWSER mode, actions I performed:
  • Add a "z" to the front of an image's name, press F5 to refresh, the Thumbnail order is not re-sorted.
    Rotate an image using Ctrl+Shift+R, and then press F5 to refresh, Thumbnail not changed.
But after restarting MP, the thumbnails are updated.
I've tried to refresh from menu, nothing happened;
I also changed the refresh key to F12 or CTRL+F5, nothing happened.
However, actions like file deletion/moving is immediately updated.
There is still a problem when adding new files. I have disabled "New files are added to the end of the list" in options.
But the new files are still added to the end of the list, even they should be sorted to a higher position.
A third minor problem is about losing focus.
When switching out to another window and switching back to MP (using alt+TAB),
the originally selected thumbnail is still highlighted,
but it has to be clicked once with the mouse before interacting with it.
Re: 0.51 XP: Thumbnail not refreshed after rename, rotate
laufu wrote:In BROWSER mode, actions I performed:
ok
I can't reproduce, thumbnail is updated without F5
I've tried, and files are sorted. Do you add files with windows explorer?
I have no this problem on Win7
Zheitk
Post by Zheitk »
related: this http://newsgroup.xnview.com/viewtopic.php?f=62&t=26330 and this http://newsgroup.xnview.com/viewtopic.php?f=60&t=26331
laufu wrote:Add a "z" to the front of an image's name, press F5 to refresh, the Thumbnail order is not re-sorted.
the refresh action does nothing in my case, I have to double-click the "Name" column over the thumbnails (I don't remember hot to show it)
xnview wrote:Rotate an image using Ctrl+Shift+R, and then press F5 to refresh, Thumbnail not changed.
I can reproduce it, and plus: I copy some pic to rotate it, and the thumbnail only shows a windows icon:
ok the problem comes from 'create whole folder' not checked
